Diy Idle Control Valve
92LexusLS400
Hi im new to this fourm.. but yeah im trying to find out how to remove or reroute my idle control valve from the intake ..im having the ps fluid leak and the white smoke also...can anyone help me on this one? steps and pics would help alot thanks
I had the same problem. Bought a new valve for $95.00. In order to install it I removed the air filter enclosure so I could have space to grab the valve with with a vise. The plastic vessel will break doing this but then you will be able to use a fixed wrench to unthread the valve and install the new one. It is a liittle tigh space to work. Woul'nt recommend to plug the hoses cause your steering wheel will be hard to turn on idle.
