I have warranty on my car, just got it a few weeks ago. The paper work says they did all of the maintenance, along with replacing wiper blades, front rotors and pads, and rear pads.
However, I'm not sure if they actually did any other maintenance or just forgot to reset the maintenance reminder. I know I can take it to them, but I was going to reset it myself if possible. I'll take it to them for service in June.
You can probably do it if you have an OBDII reader. Or you can take it to Autozone, Advance Auto or such and
have them reset it.
If you dont know what OBDII means, read up on it at this site ---> http://www.obdii.com/
have them reset it.
Same thing happened to me 04/LS430. Called the dealer and here is the order for reset. At least it worked for me.
*Make sure only the odo is showing-not trip.
*Push and hold reset and turn the key on with the vehicle off. Light should go out.
If the AC filter reminder is on: push and hold the AC off button until it beeps.
Thanks Fremantel,
I did your reset "maint reqd" trick and it worked like a charm... I still wonder if I need service...But if something was WRONG wouldn't another light come on?
