rnaves Posted March 31, 2009 Share Posted March 31, 2009 I need help with installing a new fuel pump, i can not relocate the posting with the diagram and walkthru any assistance would be much appreciated Quote Link to comment Share on other sites More sharing options...
lexus082 Posted April 1, 2009 Share Posted April 1, 2009 You have to remove the back seat to gain access to the fuel pump "service panel". Quote Link to comment Share on other sites More sharing options...
grnsc40095 Posted April 1, 2009 Share Posted April 1, 2009 rnaves, Down load the Sc workshop manual, in the link below. Type page 2031 in top left box of pdf file and scroll to end of fuel pump process and you have your answer. http://www.zshare.net/download/5185463529a5bf95/ Can use this for a reference too, just stop before steps 3 and 4. http://us.lexusownersclub.com/forums/index...l=rear+speakers Quote Link to comment Share on other sites More sharing options...
1992LexusSC400 Posted April 1, 2009 Share Posted April 1, 2009 I have looked for you on 2 other lexus forums and cant find step by step instructions for you. But I can tell you to remove the back trunk liner, or trunk mat, then remove the back padding under your rear speakers, this simply pulls straight towards the rear of the car, and is held by metal clips. This will access your fuel tank. They said it has 8 bolts located on the top of the tank. This should get you started somewhat. Make sure to disconnect your battery first. I will keep looking for you. Sorry I couldnt be much more help! Quote Link to comment Share on other sites More sharing options...
1992LexusSC400 Posted April 1, 2009 Share Posted April 1, 2009 I hope the above links helps you out... Hes the man, when it comes to links...... Quote Link to comment Share on other sites More sharing options...
