45714LS400 Posted March 30, 2009 Share Posted March 30, 2009 i hav just bought a 1992 LS400 and just became a member of this site :). Anyways the fuel pump is not turning on and i dont know why. All relays and fuses pertaining to the fuel pump/sytem have been replaced. The car ran about a month ago but now nothing. The battery has been removed a few times, could this cause the security system to shut off the pump? Does it hav a fuel saftey switch you hav to reset? I hav been serching for days to try to find some help so anything will be great. Quote Link to comment Share on other sites More sharing options...
jcrome04 Posted March 30, 2009 Share Posted March 30, 2009 Have you checked the pump itself? Quote Link to comment Share on other sites More sharing options...
Lucky13 Posted March 30, 2009 Share Posted March 30, 2009 I had the same problem and had to replace the pump itself. In fact this is not an uncommon problem so I would not be surprised if that was the case. You can get an aftermarket pump for under 200 at Advanced Auto or a place like that and instalation is very easy. Took me about 15 min. Quote Link to comment Share on other sites More sharing options...
45714LS400 Posted March 31, 2009 Author Share Posted March 31, 2009 Have you checked the pump itself? i pulled out the fuel pump and hooked up to a battery to see if it would run and it does. I replaced the wiring to the pump and it works fine now. thanks for the tips Quote Link to comment Share on other sites More sharing options...
