dstroker Posted March 30, 2009 Share Posted March 30, 2009 After visiting Autozone for them to give the CEL code of P0446, I decided to replace the gas cap on my 2000 GS300. After replacing the gas cap, I removed the neg. lead on the battery for approximately 30 seconds and replaced it. The light stayed off for approximately 3 days and over 600 miles. It then returned again. Kind of strange that it would go for this long. Any help would be appreciated, as I know this topic has been explored a great deal. Quote Link to comment Share on other sites More sharing options...
djspawn00 Posted March 30, 2009 Share Posted March 30, 2009 Did you replace it with an OEM gascap? This link may provide insight to some of the causes. http://www.clublexus.com/forums/gs-second-...eplacement.html Quote Link to comment Share on other sites More sharing options...
ZFORCE Posted April 18, 2009 Share Posted April 18, 2009 I was plagued by this code and replaced the gas cap and the O ring. Still got the code. I found the cure!!! But I'm not sharing....just kidding! I will share on one condition, you share your results here for others! Go to Home Depot, Ace Hardware or Lowes. Buy some silicone lubricant, not the aerosal type, but the liquid type, or the stuff in a tube. It's used for plumbing O rings. Grease up that Oring and tighten down slowly, if you tighten fast, the cap clicks and will not tighten as much. Keep it greased and your problems are over! Please let us know if it works for you! After visiting Autozone for them to give the CEL code of P0446, I decided to replace the gas cap on my 2000 GS300. After replacing the gas cap, I removed the neg. lead on the battery for approximately 30 seconds and replaced it. The light stayed off for approximately 3 days and over 600 miles. It then returned again. Kind of strange that it would go for this long. Any help would be appreciated, as I know this topic has been explored a great deal. Quote Link to comment Share on other sites More sharing options...
