My GS 400 is having a problem with O2 sensors. The check engine light comes on with PO171 Bank 1 code. I have replaced all the O2 sensors, But the check engine light won't go off and it's still showing the same code, PO171 bank 1. I also failed the smoke check because of the code. Any advises and suggestions is Greatly appreciate. Thank you.
There are a gazillion threads on this issue. Select "Search" (look to the upper right of this screen) ... "More Search Options" ... put PO171 in the
"Search by Keywords" field ... limit the search to more recent threads, etc. etc.
I had the exact code, and it was NOT the O2 sensor, despite what everyone says. My 00 GS300 started with that code, and then gradually started backfiring. I ran a continuity check on the plugs and found 3 bad plugs. Replaced the plugs with the dual electrode NGKs and the code disappeared.
