My Windows Wont Open, Someone Help Me
i have no idea what happened to my car. none of my windows will roll down, and the sunroof wont open its not the windows lock and i pulled and checked every fuse in the car. the power locks still work to. anyone have any ideas?
I am having the exact problem with my 93 GS300. Did you find out what the problem is? Thanks
It sounds like a fuse. If you had only one window that didn't work that would be one thing, but if it effects all 4 of them, it sounds like a bad fuse. Just check for the one that controls that unit and replace it. The whole process should only cost you 50 cents or less.
