97 Es300 Wiring Diagram
jontsp
I don't think you need an electrical diagram for your car. All you need is a test light to find a 12V and it shouldn't be difficult to find someplace to attach a ground wire. For example, if you attach to the wire for the accessory (cigarette lighter) circuit, both a 12V and a ground wire are in the same cable.
You could also attach the 12V to the underdash fuse box using an "add-a-circuit" fuse -- they are made for powering add-on accessories. See attached photo.
Thanks so much for the reply! Its highly appreciated and helpful!
