Air Filter
Where is the air filter located on a 2007 IS 250? Thanks.
Standing in front of the engine compartment it is under the cover on your left side. You will need to remove the cover by pushing in the center of the snaps, then pulling then off. I believe it shows this in the service manual, which you can findon this site.
B)
Besides the many reputable after-market air filters that are available for the IS250, - does anyone know what the actual OEM factory part number is???
Thanks!
I believe this information will be helpful for those who will have the need to know. B)
LEXUS IS250
Engine number: 2.5 L 4GR-FSE V6
OIL FILTERS:
OEM number: 04152-YZZA2 or 04152-YZZA3
FULL: A6002-180824
FRAM Filter: part number: CH10158
PUROLATOR Premium Plus: L25609
WIX: 57173
Oil Filter Wrench:
OEM SST number: 09228-06500-02
Assenmacher Specialty Tools: TOY-640
• 64mm with 14 flats = Use in conjunction with a 24mm or 15/16" socket.
ENGINE AIR FILTER:
OEM number: 17801-31110
PUROLATOR: A35798
HKS Filter: 70017-AT016
FULL: B1000-170415
BLITZ: 59570
FRAM: CA10347
K&N: 33-2345
WIX: 49146
CABIN AIR FILTER:
OEM number: 87139-YZZ05
PUROLATOR: C35667
Hastings: AF1225
FRAM: CF10285
WIX: 24511
Oil filter wrench purchase
Tool Rage, http://toolrage.com (Prod. # ASM-TOY640)
The Tool Warehouse, http://www.thetoolwarehouse.net (Prod. # ASTTOY640)
Sewell Lexus Parts, http://www.sewellpartsonline.com (Item: 09228-06500-02)
