Bill V Posted February 20, 2009 Posted February 20, 2009 I've been reading in previous posts about the Center Differential Lock switch that is available on LX470's and non US versions of the LX450's. Have I got this correct? Can this be purchased from Toyota. What is part number? Where is wiring for this located? Can 285's be installed on stock suspension and have enough clearance? On Edit: Found what I was looking for from MAN-A-FRE on the net. They had the switch I needed.
dougjohn2 Posted February 23, 2009 Posted February 23, 2009 I've been reading in previous posts about the Center Differential Lock switch that is available on LX470's and non US versions of the LX450's. Have I got this correct? Can this be purchased from Toyota. What is part number? Where is wiring for this located? Can 285's be installed on stock suspension and have enough clearance?On Edit: Found what I was looking for from MAN-A-FRE on the net. They had the switch I needed. you can also get one from American Toyota in ABQ, NM.
Bill V Posted February 24, 2009 Author Posted February 24, 2009 Thanks for the info, mine should be here any day now but if this falls thru I'll give them a try.
CELICA XX Posted December 20, 2009 Posted December 20, 2009 Also can be purchased here: http://www.sleeoffroad.com/products/products_switches.htm
