Coolant - Red Or Pink
dudhi
I noticed my coolant was getting low, so went and got the RED coolant from the dealer(He told me before 2003 should use RED). I just bought my 200 lexus es300 last year and can't tell if its using RED Antifreeze or not ( It looks pink to me but I am not sure about it).
Question: Can I use my RED one (after diluting of course) in my car without flushing the other kind(if it is pink) ? (Just don't have time right now and its freezing cold out there) Will there be a problem if I mix the two ?
TIA.
...i don t think a 50/50 mix of red added would hurt anything, but i suggest you get the system flushed and filled next time you get a chance. Have the system pressure tested to find any leaks. I assume the coolant level went down due to evaporation. Make sure that is the case.
