derekchiou Posted February 17, 2009 Share Posted February 17, 2009 Hi everyone, The following fix is for 2006 RX 400h headlight and I believe it can be applied to all others. I bought my 2006 RX 400H two months ago and it has headlight condesnation problem since day one (driver side). I check online and can't really find any helpful information. Most of the people has it fixed under warranty but unfortunately mine is out therefore I decide to try to fix it myself before spending thousand dollar on a new one. first, you have to take out the headlight assembly, there are totally 4 bolts you need to loose up and also you need to take out part of the bumper in order to slide the headlight out. Here is the look of the headlight from the back: Once you take it out, you will be able to access all the light bulbs. I found that almost all the rubber O-ring on the bulb socket were cooked. See the picture below and you will understand what I'm talking about. I believe that's where most of the mostiure/water get in the headlight. I bought my new O-Ring assortment from Harbor Freight. 20 bucks for the whole box. Once you replace all the broken O-Rings, you might want to try to seal the assembly along the cover with outdoor silicon to stop the water leaking in from the side. Remember to tape it first, you don't want the silicon to ruin the cover. You will see a gap between the lens/cover and the assembly body. Just fill up that gap and wait for it to cure. While you waiting the silicon to cure, use the hair dryer to dry up all the mositure trap inside. It might take from 10 mins to an hour depend on how much of water were traped inside. And that's it !! put the headlight back in carefully and don't wash the car for couple days to let the silicon fully dry. My headlight doesn't have any condesnation problem since then, I drove it in the rain and also on highway speed for couple weeks and it's still clean!! I believe the fix is fairly easy, everyone should be able to finish it within hours :) Good luck!! Cheers, Derek Chiou Quote Link to comment Share on other sites More sharing options...
BillyShaft Posted February 17, 2009 Share Posted February 17, 2009 Awesome writeup! Thanks Derek! Quote Link to comment Share on other sites More sharing options...
jessiecreasy Posted May 19, 2009 Share Posted May 19, 2009 Ensure the headlight capsule is secured, with "O-ring" intact. Perhaps park in the sunlight? Lexus GS Lease Lexus GS Parts Lexus LS400 Salvage Quote Link to comment Share on other sites More sharing options...
Sunapollo Posted May 19, 2009 Share Posted May 19, 2009 Good job ! my driver's side headlight also had condensation but it's gone for a while ... gotta bring it in to dealership to have them replace it when I see it next time. Quote Link to comment Share on other sites More sharing options...
