Ls400-99 Accelater Problem
LS400-99
Hi all,
First I am a new user in your forum and I would like to thank you all for this usefull forum.
Then, I need your help in my LS400-99 problem.
Problem description and History:
I was driving my LS400 slowly and suddenly a stone(or tough rock :angry: ) hit the oxegen sensor (or Exhaust Gas Sensor )
which is located in the front-left side of the car and specifically attached in the exhaust from one end (the sensor) of the cable and the other end is attached
in (??? I do not know what is called :rolleyes: ).
Result of the problem:
The result of this problem lead first in destroing the oxegeng sensor. After that the car accelater can not exceed 3 and the speed can not exceed 140km/h.
So can any one help me on this?
Thanks
:rolleyes:
Hi Again,
I forgot to tell you what I did to solve the problem(which is still until now not solved)
I took it to the technician and he did the following:
1. The Oxegen sensor was replaced.
2. The air mass filter was replaced.
3. The fuel filter was replaced.
And still the problem is not yet solved
