EPIC Posted January 9, 2009 Share Posted January 9, 2009 Ive got a 2002 is300, i just tried to replace my cluster with 2 diferent ones, and for some reason my rpm gauge dosent work, nor do the backlights work(on both). all the "christmas tree" lights work(check engine, door open, tire preasure, etc) but cant figure out why rpm dosent move and backlights dont turn on. the dimmer control works, all the lights in the dash like AC/Heater etc work. Someone know what the problem might be??? Quote Link to comment Share on other sites More sharing options...
jthao Posted September 25, 2009 Share Posted September 25, 2009 Ive got a 2002 is300, i just tried to replace my cluster with 2 diferent ones, and for some reason my rpm gauge dosent work, nor do the backlights work(on both). all the "christmas tree" lights work(check engine, door open, tire preasure, etc) but cant figure out why rpm dosent move and backlights dont turn on. the dimmer control works, all the lights in the dash like AC/Heater etc work. Someone know what the problem might be??? anyone?? I have this same problem, can't figure out what's wrong. I've tried two clusters that I know for a fact that works, but when it's on my car, same problem. RPM don't work, neither does the back lights. help?? Quote Link to comment Share on other sites More sharing options...
bartkat Posted September 25, 2009 Share Posted September 25, 2009 Maybe these PDF's will help. comb._meter_circuit.pdf comb._meter_components.pdf comb._meter_dissasembly.pdf combination_system_location.pdf comb._meter_inspection.pdf Quote Link to comment Share on other sites More sharing options...
jthao Posted September 25, 2009 Share Posted September 25, 2009 thanks! I'll give it a try and see what happens. Quote Link to comment Share on other sites More sharing options...
