Gearbox Woes
sunbeam63
probem started when the gearbox started slipping and after checking under the car found there was a leak from the transmission oil cooler located in the wheel arch.repaired the leak and pressure tested the cooler replaced the fluid,now the car will only travel forwards even when reverse is selected.drove the car in low then second and finally in drive but still no joy .car will go to about 40mph but will not go thru the gears.have switched the speed sensors over but still no joy.any thoughts.
