Mylesf7 Posted December 12, 2008 Share Posted December 12, 2008 Hello! I am having a P1354 Code on my 1999 ES300... It is also pulling misfire codes all cylinders on Bank 2 (2,4, and 6) My first thought was engine sludge (265,000miles on the car) so I pulled off the valve cover and no sludge... SO next I thought its probably the bank 2 OCV... I pulled out both valves... I took a 9v battery and they both click open and closed when I touch the leads with the wires from the 9v... Does this mean that the valves are both ok? I'm hoping its not the ECU but its looking more and more like thats what it is... Thank you a TON for any help!!! Quote Link to comment Share on other sites More sharing options...
George_Jetson Posted December 13, 2008 Share Posted December 13, 2008 First, check the wire harness closely, make sure that the harness is not rubbing against anything. You could also try swapping the valves for one side to the other, if you get a P1349 (code for the left bank). Quote Link to comment Share on other sites More sharing options...
elbrouse Posted January 6, 2011 Share Posted January 6, 2011 First, check the wire harness closely, make sure that the harness is not rubbing against anything. You could also try swapping the valves for one side to the other, if you get a P1349 (code for the left bank). Unfortunately, OCV's for right and left banks are not interchangeable. Quote Link to comment Share on other sites More sharing options...
