dg1 Posted December 4, 2008 Share Posted December 4, 2008 Just replaced the battery on my 2004 gx470. The left front turn signal also was not working. After replacing the battery the turn signal now works. What gives? Is it a sign of another problem?? Quote Link to comment Share on other sites More sharing options...
The G Man Posted December 4, 2008 Share Posted December 4, 2008 Maybe you got lucky and something reset itself or maybe the problem is random. Quote Link to comment Share on other sites More sharing options...
HienHLC Posted December 5, 2008 Share Posted December 5, 2008 Maybe you got lucky and something reset itself or maybe the problem is random. How about the left rear turn ? If it good :check the wire connector of signal lamp, or bulb die. Quote Link to comment Share on other sites More sharing options...
helloclint Posted December 18, 2008 Share Posted December 18, 2008 My right turn just started blinking at mach 3. Really really fast. The left one is normal and slow, like a heartbeat. I looked at it (from outside the car) and the right rear was flashing like a hyperactive child. The front light was dead. Is the increased blink speed some kind of indicator of a problem (in this case blown bulb?) or does it perhaps indicate a bigger problem? Or do I just need to change the battery? ;) Thanks, 2004 GX470 Quote Link to comment Share on other sites More sharing options...
BillyShaft Posted December 18, 2008 Share Posted December 18, 2008 My right turn just started blinking at mach 3. Really really fast. The left one is normal and slow, like a heartbeat. I looked at it (from outside the car) and the right rear was flashing like a hyperactive child. The front light was dead.Is the increased blink speed some kind of indicator of a problem (in this case blown bulb?) or does it perhaps indicate a bigger problem? Or do I just need to change the battery? ;) Thanks, 2004 GX470 Typically the circuit will double-cycle when one of the bulbs is out. It's just trying to let you know something is amiss! Change that front bulb and you should be back to normal. HTH, ~Brian Quote Link to comment Share on other sites More sharing options...
helloclint Posted December 23, 2008 Share Posted December 23, 2008 2004 GX470 Typically the circuit will double-cycle when one of the bulbs is out. It's just trying to let you know something is amiss! Change that front bulb and you should be back to normal. HTH, ~Brian Thank you very much, makes sense, will order up some bulbs! Quote Link to comment Share on other sites More sharing options...
