Is300-t Last Sight Of Daylight...
stirling
Well, then.... :rolleyes:
Why just replace the head gasket? If it's going in the garage for awhile, might as well open it up and replace the internals, and go over the head. Then repalce the head gasket and bump the boost to 20 psi!
snapped these before i pulled her into the garage til who knows when...and then touched a few of em up :whistles:
the headgasket blew so im building the bottom end and putting in a thicker head gasket and head studs :D
thats what im doing man :rolleyes: !!!!
---Eagle rods, JE pistons 87mm, ARP headstuds, HKS head gasket, NGK plugs & wires---
would think it is safe to boost 20psi on that...after i break it in and run a standalone?
Oh, I somehow didn't see that in your first post. Sorry. But, good to hear you are doing it.
I haven't used Eagle before,(Carrillo fan here) but everything else looks great. Are you doing any head work?
I wouldn't even port the head. Stock flows really well. Surprisingly well. I would just replace the valve train while it's off instead. If your on a budget, I would be more concerned with building a boost safe motor than looking for more power.
It depends on where you get em from and who you know. For turbo applications, I would go with Ferrea Super alloy valves. (No titanium for turbo!) Stock size is 99.1 mm length, 29 mm head, 5.98 stem diameter, 3.5 tip length. I think the part number you want is F1499P if I remember right. Don't quote me on the part number though. Intake valves should cost (retail) around $250.00 and exhaust should be about the same. Then I strongly reccomend dual spring valve springs, but those are gonna set you back around $400. And the retainers are gonna be around $300. If you decide to go with this set up, make sure you get the seat locators for the springs. But this set up will hold very nicely for you. You can definately run full boost applications and not have any worries.
