No Heat?
ls400_1999
Hi,
If I set the temperature control to 70-72 F (while outside is around 50 F) and put it in auto mode, all I get now is "cool" air from the front vents (both left/right and middle vents). If I crank the temperature up to max (85 F) then I got hot air coming out from there but only if I change to manual mode. However, I do get some hot air from the 2 bottom vents that blow to the driver/pass legs even the temperature is set back about 75 F. It starts to get cold around here and I don't want to freeze butt off while driving it. Any suggestion is very much appreciated!
I did check the coolant level and it is at its max (as indicated by the mark on the reservior tank?) and I used a flash light to look around and did not see any thing that is leaking. I bought this car since new and love every minute of it. Plan to use it forever :)
Thank you
My car is 1999 LS400 97K miles (timing belt/water bump replaced at 90K miles)
Tony
