BEARCATJER Posted October 25, 2008 Share Posted October 25, 2008 I own a 2002 rx 300 which we have had since it had 9000 miles on it. It has always worked perfectly and now has 109,000 on it. It is primarily my wife's car and today when she was out in it the VSC and check engine light came on. I looked it up in the manual and under both it said to take the car to a lexus dealer. I live 85miles from the closest dealer so I dont want to do that if I can avoid it. I dont have a local mechanic who has the computer equip to diagnose this kind of problem so i may have no choice.Does anyone have any idea what could be causing this and whether or not it is serious? I had the 90000 mile service done on this car and it runs like a top, but this has to be tended to for sure. I may see if the toyota dealer 30 miles from where i live will/can work on it. thanks for your help. :cries: Quote Link to comment Share on other sites More sharing options...
smyrnagc Posted October 25, 2008 Share Posted October 25, 2008 Had the exact same thing happen to our 2002 RX 300. It turned out to be a faulty gas cap ($7 fix) and the hose under the air filter box had come off. Do a search on this forum, or Google for that matter, and you will find several threads on this problem and how to fix it. I would do a little research and try to fix it yourself before taking it to the Lexus dealer. They will tell you that it is the O2 sensors and want to change them out...in excess of $300. Could actually be but I would do some internet research first. If you have an Advance Auto near you they will read and clear the codes for free. Good luck Quote Link to comment Share on other sites More sharing options...
Paticake Posted October 25, 2008 Share Posted October 25, 2008 I had the same thing happen ofter an oil and air filter change. Go to Auto Zone ond get the codes, then come back here and put the codes in for a search. I was told that I needed over $1200.00 of repairs and it turned out to be the hose coming off of the air filter which I fixed myself. This is the best site and everyone is here to help... Quote Link to comment Share on other sites More sharing options...
BEARCATJER Posted October 26, 2008 Author Share Posted October 26, 2008 Had the exact same thing happen to our 2002 RX 300. It turned out to be a faulty gas cap ($7 fix) and the hose under the air filter box had come off.Do a search on this forum, or Google for that matter, and you will find several threads on this problem and how to fix it. I would do a little research and try to fix it yourself before taking it to the Lexus dealer. They will tell you that it is the O2 sensors and want to change them out...in excess of $300. Could actually be but I would do some internet research first. If you have an Advance Auto near you they will read and clear the codes for free. Good luck thank you! i do have an advance auto in town where i live. will try that first. Quote Link to comment Share on other sites More sharing options...
khalifa Posted October 26, 2008 Share Posted October 26, 2008 I own a 2002 rx 300 which we have had since it had 9000 miles on it. It has always worked perfectly and now has 109,000 on it. It is primarily my wife's car and today when she was out in it the VSC and check engine light came on. I looked it up in the manual and under both it said to take the car to a lexus dealer. I live 85miles from the closest dealer so I dont want to do that if I can avoid it. I dont have a local mechanic who has the computer equip to diagnose this kind of problem so i may have no choice.Does anyone have any idea what could be causing this and whether or not it is serious? I had the 90000 mile service done on this car and it runs like a top, but this has to be tended to for sure. I may see if the toyota dealer 30 miles from where i live will/can work on it. thanks for your help.:cries: If your engine working properly ..... remove battery wire for five minutes after that I think every thing will be good Quote Link to comment Share on other sites More sharing options...
Tim Dula Posted October 27, 2008 Share Posted October 27, 2008 Any Check Engin Code will bring on the VSC Trac Light. Just overfilling with Gas will light it up. Have the code read, Fix the problem, Clear the code all is well. Quote Link to comment Share on other sites More sharing options...
BEARCATJER Posted October 27, 2008 Author Share Posted October 27, 2008 I own a 2002 rx 300 which we have had since it had 9000 miles on it. It has always worked perfectly and now has 109,000 on it. It is primarily my wife's car and today when she was out in it the VSC and check engine light came on. I looked it up in the manual and under both it said to take the car to a lexus dealer. I live 85miles from the closest dealer so I dont want to do that if I can avoid it. I dont have a local mechanic who has the computer equip to diagnose this kind of problem so i may have no choice.Does anyone have any idea what could be causing this and whether or not it is serious? I had the 90000 mile service done on this car and it runs like a top, but this has to be tended to for sure. I may see if the toyota dealer 30 miles from where i live will/can work on it. thanks for your help.:cries: If your engine working properly ..... remove battery wire for five minutes after that I think every thing will be good Thanks to all for your replies. I will try the things you suggest and go from there. Quote Link to comment Share on other sites More sharing options...
djspawn00 Posted October 27, 2008 Share Posted October 27, 2008 like everyone said before get the code scanned... post the code up here... we can get you more info from that point on... AUTOZONE scans for free.... Quote Link to comment Share on other sites More sharing options...
