TWISTED99 Posted October 18, 2008 Share Posted October 18, 2008 CEL is on (code 27), HEAVY steering, ABS light is on, will not shift out of park without using the override, AC blows cool/warm. All of this has happened after I took out the IAC and cleaned it. Before I cleaned it no ABS light, could shift out of park, and the steering was normal, BUT the trac light was on, code 27, same AC problem. Am I looking in the right direction at the IAC? I don't see how an o2 sensor (code 27) could be causing all these problems. ANY help would be appreciated Quote Link to comment Share on other sites More sharing options...
TWISTED99 Posted October 25, 2008 Author Share Posted October 25, 2008 CEL is on (code 27), HEAVY steering, ABS light is on, will not shift out of park without using the override, AC blows cool/warm. All of this has happened after I took out the IAC and cleaned it. Before I cleaned it no ABS light, could shift out of park, and the steering was normal, BUT the trac light was on, code 27, same AC problem. Am I looking in the right direction at the IAC? I don't see how an o2 sensor (code 27) could be causing all these problems. ANY help would be appreciated Car sat in the garage all week, went to drive yesterday and neither window will go up. I checked the fuses and all are good. Any ideas? Quote Link to comment Share on other sites More sharing options...
