The bolt pattern is the same, but a 16" wheel will require a larger profile (higher sidewall) tire in order to keep the speedometer readings correct. That size tire will also negatively affect the handling IMO.
I don't think they will clear the brake calipers.
Wait, I just went out back and checked, looks like it should fit just fine.
Thanks that's the concern I had, the brake calipers.
