My high beams are not working on my 2000 Rx300. I replaced the blubs and checked the fuses and they are all okay. Does anybody think replacing the Headlight Control Relay would solve my problem?
Well then you might need to have a pro diagnosis it before .
Do you hear a click when you activate the light stalk to high beam position and does the blue light on the cluster illuminate ?
Check your relay. It's located on the radiator grill. If it's working you will hear a clicking sound.
www.jpimportz.org
  • 3 years later...
www.jpimportz.org
Do you guys know of a place to get the relays other than the dealer? Also, to make sure, are the relays that control the high beams located in the pod that is actually attached at the radiator? Has a black, and 2 burgundy relays plus 1 fuse?
Thanks! Jeff
  • 4 months later...
www.jpimportz.org
Thanks! Jeff
I'm having the same problem on my 99 RX-300. Did the relay fix the problem?
