vroom8 Posted September 7, 2008 Share Posted September 7, 2008 0 no...I just got my coolant changed again, and I think they filled it too full. Is it normal for it to throw some out/ the hose or something? Leak under TB area. not alot, but I have never seen that before. Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted September 7, 2008 Share Posted September 7, 2008 If your cap is working properly then it's most likely releasing the excess pressure out through the tube running down the side of the expansion tank. You can minumize the spill by getting back to the proper levels with a turkey baster. Quote Link to comment Share on other sites More sharing options...
vroom8 Posted September 7, 2008 Author Share Posted September 7, 2008 If your cap is working properly then it's most likely releasing the excess pressure out through the tube running down the side of the expansion tank. You can minumize the spill by getting back to the proper levels with a turkey baster. thanks...it is a brand new tank/cap. that is probably it. Quote Link to comment Share on other sites More sharing options...
