lexrx3 Posted September 6, 2008 Share Posted September 6, 2008 I started my 2001 RX 300 AWD the other morning and after driving 1 1/2 miles the VSC light and check engine light came on. My local mechanic that does most of my work couldn't imediately find the issue. He cleared it but its back on. This will take more time to track down the cause. He says he'll probably be able to find it but it will take time. The dealer will be faster I'm sure but more costly. The car runs fine and nothing seems diferent. Can anyone tell me what may have caused it? Any help is appreciated so that we don't take all day locating the problem. 70,000 miles. Thanks. Quote Link to comment Share on other sites More sharing options...
jgr7 Posted September 6, 2008 Share Posted September 6, 2008 Did you check your gas cap? Quote Link to comment Share on other sites More sharing options...
pitorro7306 Posted September 9, 2008 Share Posted September 9, 2008 Did you check your gas cap? hi, i got an RX300 and it does the same. i bought a new gas cap, but it continues doing it. Quote Link to comment Share on other sites More sharing options...
David Anshen Posted September 12, 2008 Share Posted September 12, 2008 Did you check your gas cap? hi, i got an RX300 and it does the same. i bought a new gas cap, but it continues doing it. Did you get an oil change recently? Quote Link to comment Share on other sites More sharing options...
mikew Posted December 2, 2008 Share Posted December 2, 2008 Check the hose attached behind the air cleaner assembly. It will come loose when you pull on the assembly. It will throw a CEL light. Quote Link to comment Share on other sites More sharing options...
Paticake Posted December 3, 2008 Share Posted December 3, 2008 Had the same thing happen. Check the hose behind the air filter box.(that was my problem). If that IS connected, then to Auto Zone and have the codes read, then come back and post, or do a search for those codes... Good luck and let us know how you make out. :0) Quote Link to comment Share on other sites More sharing options...
rx416 Posted December 4, 2008 Share Posted December 4, 2008 I started my 2001 RX 300 AWD the other morning and after driving 1 1/2 miles the VSC light and check engine light came on. My local mechanic that does most of my work couldn't imediately find the issue. He cleared it but its back on. This will take more time to track down the cause. He says he'll probably be able to find it but it will take time. The dealer will be faster I'm sure but more costly. The car runs fine and nothing seems diferent. Can anyone tell me what may have caused it? Any help is appreciated so that we don't take all day locating the problem. 70,000 miles. Thanks. I have the same problem... You can check the 02 sensor Quote Link to comment Share on other sites More sharing options...
lexrx3 Posted December 4, 2008 Author Share Posted December 4, 2008 I started my 2001 RX 300 AWD the other morning and after driving 1 1/2 miles the VSC light and check engine light came on. My local mechanic that does most of my work couldn't imediately find the issue. He cleared it but its back on. This will take more time to track down the cause. He says he'll probably be able to find it but it will take time. The dealer will be faster I'm sure but more costly. The car runs fine and nothing seems diferent. Can anyone tell me what may have caused it? Any help is appreciated so that we don't take all day locating the problem. 70,000 miles. Thanks. I did look for the hose that many had mentioned but everything was connected. I took it to Autozone and the code was P1135 indicating the AF Sensor. I then had it replaced for $200. The lights are off and everything is fine. Thanks for the responses! Quote Link to comment Share on other sites More sharing options...
giahamzui Posted December 6, 2008 Share Posted December 6, 2008 Check the hose attached behind the air cleaner assembly. It will come loose when you pull on the assembly. It will throw a CEL light. thank you . it's work like a charm ... Quote Link to comment Share on other sites More sharing options...
