hey i'm changing my timing belt and water pump, got the instructions but i dont know the torque specs for each bolt. does anyone know where i can get one (online)? and is it crucial in this case? thanks
It is crucial. I don't know of anywhere on line to get those other than here. There might be a link somewhere, but I don't have it. I'll try to check the manual tonight and post them up.
oh, i need torque specs for the bolts i will be handling with while taking off the timing belt and water pump. i dont want to either over- or under-tightening any bolt.
Hi, I heard you're doing a timing belt chang. IF possible when you're done with the chang with the belt and the water pump can you post it in here or email me of the bolt specs and how to complete the belt and water pump change. I really need to replace those two vital part on mine too. I would really appreciate it if you can. Thanks,
hey chang, got my removal/installation instructions from lextreme.com. fairly detailed with pictures. i will post the torque specs once i get a hold of it
