Gary K Posted August 24, 2008 Share Posted August 24, 2008 I have an 03 ls430 with 52000 miles. On cold startup I sometimes get a misfire followed by a check engine light and vsc off indicator. The local Auto zone code reader showed a P0301 cylinder one misfire. I removed and reseated the number one coil and the misfire was ok for a couple weeks put it has returned. Is replacing the coil the most likely fix for this? Also, is there any easy way to get at the plugs other than a long extension and a blind turning. Thanks. Quote Link to comment Share on other sites More sharing options...
SRK Posted August 24, 2008 Share Posted August 24, 2008 The misfire code is triggered by the crankshaft position sensor detecting an acceleration difference between cylinders - that's how the ECM knows it's number one. The acceleration difference is either spark or fuel - compression problems would be constant. You should check the injector, and have it cleaned professionally. I'd suspect the injector as being slightly fouled before a very intermittent ignition coil. Quote Link to comment Share on other sites More sharing options...
Gary K Posted August 25, 2008 Author Share Posted August 25, 2008 Thanks, I'll check the injectors and probably clean them. Quote Link to comment Share on other sites More sharing options...
ss350z Posted April 19, 2021 Share Posted April 19, 2021 I have had this problem. In my case it seems to have been a fuel issue. I had a check engine, with multiple misfire issues on different cylinders and the VSC off. I had the problem from bad gas, after my car sat for over a year. It took driving 2000 miles with lots of fuel injector cleaner, and it finally cleared up. Quote Link to comment Share on other sites More sharing options...
