AdamIsAdam Posted August 18, 2008 Share Posted August 18, 2008 Yesterday I changed the fluids in my wife's RX330 (04). The tranny has the 10mm hex nut, so that was easy enough. I had read that there's a second 10mm drain plug near by for the transaxle which also works with ATF, but I never found it. However, about 5qts of tranny fluid came out. The front differential bolts, 15/16", I couldn't get a wrench on them! specifically, not a ratchet & socket. And I didn't have a box wrench that size. Any tips on this? The rear diff couldn't be any easier. I do love drain plugs on differentials! Tips welcome! Quote Link to comment Share on other sites More sharing options...
v-rodder Posted August 19, 2008 Share Posted August 19, 2008 Yesterday I changed the fluids in my wife's RX330 (04). The tranny has the 10mm hex nut, so that was easy enough. I had read that there's a second 10mm drain plug near by for the transaxle which also works with ATF, but I never found it. However, about 5qts of tranny fluid came out.The front differential bolts, 15/16", I couldn't get a wrench on them! specifically, not a ratchet & socket. And I didn't have a box wrench that size. Any tips on this? The rear diff couldn't be any easier. I do love drain plugs on differentials! Tips welcome! Quote Link to comment Share on other sites More sharing options...
carguy07 Posted August 19, 2008 Share Posted August 19, 2008 This thread will explain everything: http://www.clublexus.com/forums/showthread.php?t=220061 Pics of the trans-axle plug borrowed from that thread. The 15/16" drain plug is for the transfer case and it takes gear oil. I got an open end wrench from Ace Hardware and it fit fine. I'm not sure if the your RX330 takes more fluid than my RX300, but mine only needs about 4 1/4 quarts to refill including the trans-axle. Quote Link to comment Share on other sites More sharing options...
AdamIsAdam Posted August 19, 2008 Author Share Posted August 19, 2008 yea, I read that thread, all 99 pages. It was very helpful in proving i'm not insane. I guess the RX330 is different, as I do NOT have that drain plug. At least I feel better! Is it also true that the RX330 doesn't have a serviceable filter? as for the wrench, I'll hit the hardware stores this week. Thanks. Quote Link to comment Share on other sites More sharing options...
tp3366 Posted September 6, 2008 Share Posted September 6, 2008 Did you do the fluid change in transfer case and rear differential? Do yiou have any writeup or details how to do it? thanks tp3366@yahoo.com Yesterday I changed the fluids in my wife's RX330 (04). The tranny has the 10mm hex nut, so that was easy enough. I had read that there's a second 10mm drain plug near by for the transaxle which also works with ATF, but I never found it. However, about 5qts of tranny fluid came out.The front differential bolts, 15/16", I couldn't get a wrench on them! specifically, not a ratchet & socket. And I didn't have a box wrench that size. Any tips on this? The rear diff couldn't be any easier. I do love drain plugs on differentials! Tips welcome! Quote Link to comment Share on other sites More sharing options...
Matej Posted September 10, 2008 Share Posted September 10, 2008 The worst car = Audi 100 yr 1988. Bought new, driven for 10 years, sold with value of 700USD (15.000.- SKK) Quote Link to comment Share on other sites More sharing options...
