Hi I have a 1995 Lexus SC 400 and am having trouble starting it due to bad gas. I had the fuel filter changed once already a the shop and it ran that day but they didnt empty the bad gas. i put some fresh gas and fuel treatment into it bu now it wont start again. Can anyone tell me where the fuel filter is located so i can check it out? also any other suggestions would be appreciated. Thank You.
Under the car, just in front of the driver side rear wheel
are you sure its due to fuel,as there is a fuel ecu that fails in normal run mode but ok in start up mode , which means the car will start but almost immediatly stop.
That's a good point. It might be something else all together, and usually bad fuel will hurt the Piston Rings, Fuel Injector, and the pump itself. Can you provide us with some more details on what happens when you try to start your car up?
