Door Electrical Wiring Boot
frego
Hi gang,
What is the "rubber boot" called that the electrical wiring that runs from the chassis into the doors called? How difficult is it to replace, mine are toast? Do you have to disconnect every individual wire and tread it through, or is there one "universal" connector in the door or engine compartment where all wires run to?
Thanks
Hi gang,
Thanks
Why not use some "spiral wrap tubing" to repair the rubber boot? I googled it and found a company that sells them. You might be able to get it at the local hardware store in the electrical section. I used to use it when working on aircraft. With the spiral wrap, you don't have to disconnect either side. You just start wrapping it arounc the damaged section.
