miked Posted December 15, 2003 Share Posted December 15, 2003 do you guys recommend a filter change when doing a tranny flush ? the filter was change previously about two weeks before. the mechanic just drained and filled and change the filter and then i decided to have someone else do a tranny flush( he does not have the machine). is it true that the filter could get clogged and caise a problem. Pls let me know! Quote Link to comment Share on other sites More sharing options...
miked Posted December 16, 2003 Author Share Posted December 16, 2003 cmon guys- help me out! Quote Link to comment Share on other sites More sharing options...
miked Posted December 17, 2003 Author Share Posted December 17, 2003 guys help me out- do i need to replace the filter- after the mechanic repl the filter and did a drain/fill i felt that i needed to do a flush but did not replace the filter again is it true that the filter gets flush also and does not need to be replaced or should i replace again ! let me know i need your help! Quote Link to comment Share on other sites More sharing options...
JPI Posted December 17, 2003 Share Posted December 17, 2003 What make you think you have to change the filter when flushing the ATF? There are 3 magnets inside the transmission pan. They will collect all the shaving so you don't have to change your filter. Sorry this is not a FORD. www.jpimportz.org Quote Link to comment Share on other sites More sharing options...
miked Posted December 17, 2003 Author Share Posted December 17, 2003 jpi, thx for responding- i thought that any crud that might have been removed i'm sure they used a clear flush treatment - might clog up the filter ! what do you think! Quote Link to comment Share on other sites More sharing options...
gserep1 Posted December 17, 2003 Share Posted December 17, 2003 Hello, I assume that you have a GS300 or 400 right? If so, then the only filter you have is a "screen" that can be cleaned, not replaced. The only time I would replace that screen would be if the screen is damaged or has a big hole in it. If the transmission fluid is changed regularly, cleaning that screen should not be necessary. Thanks, GSEREP1 Quote Link to comment Share on other sites More sharing options...
miked Posted December 17, 2003 Author Share Posted December 17, 2003 gserep1, thx- yea it's a 1993 gs 300 -but if you look at my earlier post in this thread- i replaced the screen/filter before i did a flush - would i need to change it or clean it ? i have no ramps(or time) so i would have to get somebody to do it! do you think it's necessary or does the flush also clean off the screen/filter? thx Quote Link to comment Share on other sites More sharing options...
