How Can You Tell If A Rx300 Is Awd?
Just look underneath at the rear end. If you see a differential and axles/drive shaft then it's AWD. I think the FWD cars have a traction control button in the center console. Not sure if that applies to all years or not, but the early ones had the button.
I'm pretty sure you can look at the VIN too. If the 4th character is H then its 4 AWD if its G then its FWD.
Sounds easy enough. Thanks
