Radio Advice
I'm assuming you're buying used radios due to the discontued nature of the JVC radio... just keep in mind that with either radio you're still going to have to bypass the factory amp and you will lose use of the factory sub... so if you're going to go through the trouble I'd say spend a lil more and upgrade.
im getting neither. I was going to get one because the screen on my stock does not have a display. So your saying if i install ANY after market radio i will most likely have to buy an amp for it too?
