scottelble Posted July 10, 2008 Posted July 10, 2008 My ABS and VSC light is on my dash. I can still hear the abs motor coming on and off....Anyone who has had to deal with this that can tell me what to expect the problem to possibly be would be a great help! Money is tight and i'm afraid the process of elimination will be costly:( Thanks in advance, Scott
Chuck Li Posted July 14, 2008 Posted July 14, 2008 it could be the speed sensor for your abs, which will cost alot unless you know some personal mechanics. this happened to my 2000 gs300 as well.
scottelble Posted July 14, 2008 Author Posted July 14, 2008 I had it checked out today...All abs wheel sensors are working properly but it did say ABS module circuit A and C failure. Anyone know if that means my ABS module is toast? The timing couldn't be worse for this $h*t to happen...GGGRRRRR!
92Lex Posted July 17, 2008 Posted July 17, 2008 When did the lights appear? Was any work performed prior to these malfunctions appearing? Have you had any suspension work done?
acha3 Posted July 24, 2008 Posted July 24, 2008 When did the lights appear? Was any work performed prior to these malfunctions appearing? Have you had any suspension work done? I have the same problem, and yes I change the ball joint and links and then these ligth are on. What can I do to reset them?? Thanks in advance
