My ABS and VSC light is on my dash. I can still hear the abs motor coming on and off....Anyone who has had to deal with this that can tell me what to expect the problem to possibly be would be a great help! Money is tight and i'm afraid the process of elimination will be costly:(
Thanks in advance, Scott
it could be the speed sensor for your abs, which will cost alot unless you know some personal mechanics.
this happened to my 2000 gs300 as well.
I had it checked out today...All abs wheel sensors are working properly but it did say ABS module circuit A and C failure. Anyone know if that means my ABS module is toast? The timing couldn't be worse for this $h*t to happen...GGGRRRRR!
When did the lights appear? Was any work performed prior to these malfunctions appearing? Have you had any suspension work done?
I have the same problem, and yes I change the ball joint and links and then these ligth are on. What can I do to reset them?? Thanks in advance
