Does anyone know if there is an override protocol for the Bluetooth screen. It would be nice to be able to dial on the touch screen while driving or press the # key skip voice mail greeting. The override to input information into the GPS while driving does not work for the Bluetooth. I'd really like to know if its out there. I have an 07 ES350. Thanks!
You can override your GPS? I thought any 2007 and beyond were not allowed to do this anymore...
You can create a special disc and replace the newer navigation software with the 5.1 loading software (the last version where the override menu was available), which would then let you retain the override menu with the latest map data (ie a 7.1/5.1 disc).
i can access the override menu and it works great for the navigation grayouts, but not the bluetooth. i may have to install a switch to disable the speed sensor. thanks for your help.
