1993 Lexus Sc 400
MY 93 SC400 HAS THE TRAC CONTROL LIGHT ON, IT'S ALSO RELATED TO THE CHECK ENGINE LIGHT THAT IS ALSO ON.
THERE ARE TIMES WHEN IT IS NOT ON.ONLY FOR 20 MINUTES OR SO.
ALSO MY CHECK RADIATOR LIGHT IS ON,I ADDED FLUID WHEN IT FIRST OCCURRED,BUT THE LIGHT
STAYED ON.
VERY NICE AUTO PEARL WHITE 125K. LOOKS LIKE A NEWER CAR.
PLEASE HELP...MILWAUKEE AREA. :rolleyes:
I have a 1992 SC400 and a 1999 Toyota Camry, and the SC had those lights on as well, just take it to the dealer and ask them, they will shut them off for you! as for my Camry, the check engine light was on, it needed a new catalytic converter! so just take it to the dealer!
If you go to AutoZone (there may be other auto parts stores that do the same). They can run a diagnosis for your check engine light. Once that is done you have a good staring point.
Good luck,
Elvis
I had that happen to me I have a 92 SC400 had it check out and was told that i needed to replace the 2 front 02 sensors, don't no about the radiator light, i have 120,000 miles on mine, let us no what you find out. good luck
