How do i reset the computer navigation system? The !Removed! is in but the readout says " no disc found"
You can take the fuse out to the radio for a few minutes or disconnect the car battery (fuse is easier). It has to be a few minutes (like 10-20) otherwise it seems to remember things. You might have to do some looking around, I don't know if the radio fuse goes to the remote DVD player.
  • 1 month later...
You need to get out the battery inside the nav ecu. But I believe that you have a bigger problem than that. Did you tocuh anything from the hides menus? There a re a lot of topics about this issue. Once the CPU is damaged, only the gen 5 (I believe) can be reset.
