wtfitsrandall Posted June 9, 2008 Share Posted June 9, 2008 hi i have a 01 gs430 and would like to change all the liquids, like the steering, transmission, brake, coolant, and oil change. i was thinking about doing it myself. any tips or ideas of how i should do it? how can i get all the liquid out so i know i can have clean new liquid in it? thanks in advance. Quote Link to comment Share on other sites More sharing options...
djspawn00 Posted June 9, 2008 Share Posted June 9, 2008 There tons of tips and tutorials on how to replace each fluid on here if you run a search. You can also check clublexus.com in their tutorial section... one thing I recommend you do is make sure you use the correct fluids for your applications. I know in my 02 GS300 I use 5w-30 for the engine, Toyota ATF IV for the Tranny, Mobil1 ATF fluid for the power steering, Castrol Synthetic Dot3 for the brake fluid, and Amsoil 75w-90 (i think i'm not sure if thats the right weight) on my rear differential. I may have listed something wrong as I may be having a mild heat stroke right now... Good Luck! What part of NY are you in? Quote Link to comment Share on other sites More sharing options...
wtfitsrandall Posted June 25, 2008 Author Share Posted June 25, 2008 There tons of tips and tutorials on how to replace each fluid on here if you run a search. You can also check clublexus.com in their tutorial section... one thing I recommend you do is make sure you use the correct fluids for your applications. I know in my 02 GS300 I use 5w-30 for the engine, Toyota ATF IV for the Tranny, Mobil1 ATF fluid for the power steering, Castrol Synthetic Dot3 for the brake fluid, and Amsoil 75w-90 (i think i'm not sure if thats the right weight) on my rear differential. I may have listed something wrong as I may be having a mild heat stroke right now... Good Luck! What part of NY are you in? hey thanks a lot for the info. I live in Brooklyn! sorry for the late reply been busy!! thanks Quote Link to comment Share on other sites More sharing options...
