Tango19 Posted June 8, 2008 Share Posted June 8, 2008 Once you record a route, and keep the route displayed on the map, can you do anything else with it? Can you save it as a destination, or if you want to re-trace the route do you just have to follow the map manually? Thanks. Quote Link to comment Share on other sites More sharing options...
SW03ES Posted June 9, 2008 Share Posted June 9, 2008 You can save the destination as a marked point, and you can reverse the directions to the spot where you entered the destination. Quote Link to comment Share on other sites More sharing options...
Tango19 Posted June 9, 2008 Author Share Posted June 9, 2008 You can save the destination as a marked point, and you can reverse the directions to the spot where you entered the destination. Thanks. So you can only follow the recorded route visually on the map as opposed to actually have the nav system give route guidance as you drive? Quote Link to comment Share on other sites More sharing options...
SW03ES Posted June 9, 2008 Share Posted June 9, 2008 You would have it reverse the route you just drove by setting the last position as the destination, then you'd have the guidance instructions. Quote Link to comment Share on other sites More sharing options...
