Ratatat Posted June 5, 2008 Share Posted June 5, 2008 does anyone, or do you know of a place where these could be had, i beleive there is 4 small ones on the sc400 center arm rest. Quote Link to comment Share on other sites More sharing options...
lemaylexus Posted June 5, 2008 Share Posted June 5, 2008 I need one of these as well. I'm just missing one on the front passenger side of the arm rest, but you can feel the armrest wobble because of that one missing piece of rubber. Not a big deal, but a minor annoyance nonetheless. Quote Link to comment Share on other sites More sharing options...
GaDawg Posted June 13, 2008 Share Posted June 13, 2008 Guys, I had the same problem. First, go to the junk yard. These grommets are the same on all Lexus' around the same year groups and I believe they're exactly the same as the Toyotas...makes sense. However, they were worn out from age and elements and didn't last too long. Lemaylexus, you may have better luck in IL than I did here in the Iowa side of the Quad Cities. Ratatat, you may have the same problem I did, but give it a shot What I ended up doing recently after the junkyard ones failed was go to the dealership and found out that they have them for, I think, a dollar a piece and you have to buy a pack of them...not too bad. It's worth it so the armrest doesn't rock all over the place. Happy hunting. Quote Link to comment Share on other sites More sharing options...
Ratatat Posted June 14, 2008 Author Share Posted June 14, 2008 did you get a part number? Quote Link to comment Share on other sites More sharing options...
