cherylsc430 Posted May 20, 2008 Share Posted May 20, 2008 My battery is new and has been checked, problem I have is that it keeps going flat after I haven't used the car for a week or so (prior to that only light use - say 20 miles/week for previous 3 weeks). Any ideas ? Is something draining my battery? No lights etc are on and the breakdown man said drainage current was ok. Can you disable the alarm but still use the immobiliser? Quote Link to comment Share on other sites More sharing options...
gordonw Posted May 20, 2008 Share Posted May 20, 2008 You need to drive the car more often or hook it up to a charger to keep the battery charged. Your "driving" isn't enough to recharge the battery. Quote Link to comment Share on other sites More sharing options...
Christian P Posted May 20, 2008 Share Posted May 20, 2008 You need to drive the car more often or hook it up to a charger to keep the battery charged. Your "driving" isn't enough to recharge the battery. i have a mustang and it sits in the below freezing new england winters and still starts in the spring Quote Link to comment Share on other sites More sharing options...
aquanuke Posted May 20, 2008 Share Posted May 20, 2008 I dont use my car for a couple of weeks regularly. When I first got the car I often got a flat battery, after I stopped using the alarm it was fine. If you can ie your car is garaged then dont set the alarm. Or get one of those switches fitted to the battery that disconnects the battery when it reaches too low, so as there is just enough juice left to turn the engine over. Quote Link to comment Share on other sites More sharing options...
