ted0804 Posted May 5, 2008 Share Posted May 5, 2008 My right front turn signal bulb burned out recently. Since the dealership charges such high prices I thought I could do the replacement myself. I found the replacement bulbs at a parts place. When I lifted the hood I discovered there is no obvious way to get to the assembly. I'm stumped. How do I access the turn signal area to replace the bulb? Thanks. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted May 5, 2008 Share Posted May 5, 2008 undo the little Phillips screw beside the fender on top of the headlight. then pull it towards the front of the car and it pops off. Quote Link to comment Share on other sites More sharing options...
ted0804 Posted May 5, 2008 Author Share Posted May 5, 2008 My right front turn signal bulb burned out recently. Since the dealership charges such high prices I thought I could do the replacement myself. I found the replacement bulbs at a parts place. When I lifted the hood I discovered there is no obvious way to get to the assembly. I'm stumped. How do I access the turn signal area to replace the bulb? Thanks. Quote Link to comment Share on other sites More sharing options...
ted0804 Posted May 5, 2008 Author Share Posted May 5, 2008 Thank you. I'll try that. Quote Link to comment Share on other sites More sharing options...
Martin S Posted August 29, 2008 Share Posted August 29, 2008 undo the little Phillips screw beside the fender on top of the headlight. then pull it towards the front of the car and it pops off. Thanks for the post. On my 1998 LS400 it saved me making the mistake of removing the headlight in an attempt to get to the turn signal light. Quote Link to comment Share on other sites More sharing options...
