Timing Belt
dlg16
I have 90k miles on my 2001 ls430 and the dealer is telling me at this level I need to have the timing belt changed. Does anyone know if this is really necessary.
Thanks
Thanks
I'm not sure of the schedule for an 01ls, but it's easy enough to find out. And yes, if it's time, then you have to change it. Make sure that the water pump and all pulleys/tensioners are replaced as well.
I just changed mine at 115K, but you do take a risk. I believe the 01 has the 'interference' engine that will cause much more damage than just a broken timing belt.
The parts themselves are not that expensive - several online parts places have them if you feel like doing it yourself or if you have a VERY trusted mechanic.
Just think of it this way - you will be good to go for another 90K!
Unless you are quite experienced in engine repairs,
I would advise against doing this yourself. Check out
this link to get an idea of what's involved:
http://www.lexls.com/tutorials/engine/timingbelt.html,
but as ultra says, you can buy the parts, have a good
mechanic do the job and save yourself some money
from going to the stealership.
Thanks for the information.This was very helpful..I made the appointment!!
