dlg16 Posted May 2, 2008 Share Posted May 2, 2008 I have 90k miles on my 2001 ls430 and the dealer is telling me at this level I need to have the timing belt changed. Does anyone know if this is really necessary. Thanks Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted May 2, 2008 Share Posted May 2, 2008 I have 90k miles on my 2001 ls430 and the dealer is telling me at this level I need to have the timing belt changed. Does anyone know if this is really necessary.Thanks I'm not sure of the schedule for an 01ls, but it's easy enough to find out. And yes, if it's time, then you have to change it. Make sure that the water pump and all pulleys/tensioners are replaced as well. Quote Link to comment Share on other sites More sharing options...
01 Ultra Posted May 2, 2008 Share Posted May 2, 2008 I just changed mine at 115K, but you do take a risk. I believe the 01 has the 'interference' engine that will cause much more damage than just a broken timing belt. The parts themselves are not that expensive - several online parts places have them if you feel like doing it yourself or if you have a VERY trusted mechanic. Just think of it this way - you will be good to go for another 90K! Quote Link to comment Share on other sites More sharing options...
sonyman Posted May 2, 2008 Share Posted May 2, 2008 Yes, it is necessary. Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted May 2, 2008 Share Posted May 2, 2008 Unless you are quite experienced in engine repairs, I would advise against doing this yourself. Check out this link to get an idea of what's involved: http://www.lexls.com/tutorials/engine/timingbelt.html, but as ultra says, you can buy the parts, have a good mechanic do the job and save yourself some money from going to the stealership. Quote Link to comment Share on other sites More sharing options...
dlg16 Posted May 3, 2008 Author Share Posted May 3, 2008 Unless you are quite experienced in engine repairs, I would advise against doing this yourself. Check out this link to get an idea of what's involved: http://www.lexls.com/tutorials/engine/timingbelt.html, but as ultra says, you can buy the parts, have a good mechanic do the job and save yourself some money from going to the stealership. Thanks for the information.This was very helpful..I made the appointment!! Quote Link to comment Share on other sites More sharing options...
