Effect Of Ignition Cylinder On Alternator
I dont believe it would have anything to do with each other but I could be wrong. I know the car needs to start but once its started the alternator should charge as normal. I could be wrong but I dont think I am. I hope this helps. If you battery is bad it could cause your alternator to not read fully.
Thanks, I ended up getting underneath and taking the alternator out. Turns out it was drenched with power steering fluid from the pump above. Waiting on the pump and then I'm going to replace both. Lots of fun. Overall not a hard job.
