bleak20588 Posted May 2, 2008 Share Posted May 2, 2008 Is there any effect of the ignition lock cylinder on the alternator? My ignition cylinder is missing and I'm having a problem with my alternator charging my battery. Quote Link to comment Share on other sites More sharing options...
BD Mobile Electronics Posted May 2, 2008 Share Posted May 2, 2008 I dont believe it would have anything to do with each other but I could be wrong. I know the car needs to start but once its started the alternator should charge as normal. I could be wrong but I dont think I am. I hope this helps. If you battery is bad it could cause your alternator to not read fully. Quote Link to comment Share on other sites More sharing options...
bleak20588 Posted May 6, 2008 Author Share Posted May 6, 2008 I dont believe it would have anything to do with each other but I could be wrong. I know the car needs to start but once its started the alternator should charge as normal. I could be wrong but I dont think I am. I hope this helps. If you battery is bad it could cause your alternator to not read fully. Thanks, I ended up getting underneath and taking the alternator out. Turns out it was drenched with power steering fluid from the pump above. Waiting on the pump and then I'm going to replace both. Lots of fun. Overall not a hard job. Quote Link to comment Share on other sites More sharing options...
