daepp Posted April 28, 2008 Share Posted April 28, 2008 Is there any way to allow the radio to continue after the engine is shut off? I have been able to do this on two MBZ's and even my F150 can do it. Quote Link to comment Share on other sites More sharing options...
The G Man Posted April 28, 2008 Share Posted April 28, 2008 Hit the push start button without stepping on the brake after the car is shut off, this will put you in the radio mode. Push the button again and you are in accessory mode, push it one more time and the electricals are off. Quote Link to comment Share on other sites More sharing options...
boB_2006_GS300 Posted April 28, 2008 Share Posted April 28, 2008 I noticed if you press the start button (to turn off the car), but the shifter is still in gear, the radio stays on even though the engine turns off. You can then shift to park. You then press the start button 3 times to go through ACC, ON, then OFF to turn off all when you are done listening. Don't know what else stays on, or if this is documented, but I found this when I forgot to put the shifter in park before turning off the car. Hope this works for you. Quote Link to comment Share on other sites More sharing options...
daepp Posted April 29, 2008 Author Share Posted April 29, 2008 I noticed if you press the start button (to turn off the car), but the shifter is still in gear, the radio stays on even though the engine turns off. You can then shift to park. You then press the start button 3 times to go through ACC, ON, then OFF to turn off all when you are done listening. Don't know what else stays on, or if this is documented, but I found this when I forgot to put the shifter in park before turning off the car. Hope this works for you. Great - I will give that a try. I was aware of how to get it back on by pushing the start button after engine start down and without my foot on the brake, but then the wheel had to move and it's just not the same. Quote Link to comment Share on other sites More sharing options...
