Difference Between 6.1 Navigation System And 7.1 Navigation
Aside from the newest mapping, there's a change in the firmware. You no longer have to push the "I Agree" button when you first turn on the Nav. You just get a "Caution" screen for about 5 seconds, and then the map comes up on the display.
  • 3 months later...
Can you directly update from a Version 2/3 to 7.1????
I think you are confusing the generation (2/3) of your navigation hardware with the most current version (7.1) navigation software.
But the answer would be yes, you can upgrade directly to version 7.1 on your generation 2/3 system (doesn't matter your current software version).
Do you guys know anything about the non-OEM discs for sale :
http://cgi.ebay.com/Lexus-Toyota-Navigatio...1QQcmdZViewItem
Also, Is the dvd inside the nav system in the trunk ? Is it easy to replace ?
Thanks!
Art Beall
