SAFRO.COM Posted April 7, 2008 Share Posted April 7, 2008 Okay I have a 97 ES300 all stock, black interior. I saw a 99 GS at work, the guy has these bright dark blue LED lights in the door panel and in the other light areas. I have the stock bulbs painted blue and it turns to green when lit. I want LEDS is there a site for these, i cant find one. please help. Can they plug into the original socket, do i need to modify the wires, do i need to change the power to the bulb? Quote Link to comment Share on other sites More sharing options...
Lexus2D Posted April 8, 2008 Share Posted April 8, 2008 U should be ok its easy 2 do in the IS Quote Link to comment Share on other sites More sharing options...
wwest Posted April 9, 2008 Share Posted April 9, 2008 Okay I have a 97 ES300 all stock, black interior. I saw a 99 GS at work, the guy has these bright dark blue LED lights in the door panel and in the other light areas. I have the stock bulbs painted blue and it turns to green when lit. I want LEDS is there a site for these, i cant find one. please help. Can they plug into the original socket, do i need to modify the wires, do i need to change the power to the bulb? Do you mean BLUE, really, actually...?? Or do you mean "Cool White", white light with a slight tint to the blue side? The Cool White LEDs are fairly common in the marketplace, start at Ebay, modern day Sears-Roebuck catalog (except for the outhouse use). Quote Link to comment Share on other sites More sharing options...
SAFRO.COM Posted April 14, 2008 Author Share Posted April 14, 2008 what is the best for looks, probably i would like the brightest without too much blue in it . so i guess the cool blue would work. Quote Link to comment Share on other sites More sharing options...
Lexucan Posted April 15, 2008 Share Posted April 15, 2008 Okay I have a 97 ES300 all stock, black interior. I saw a 99 GS at work, the guy has these bright dark blue LED lights in the door panel and in the other light areas. I have the stock bulbs painted blue and it turns to green when lit. I want LEDS is there a site for these, i cant find one. please help. Can they plug into the original socket, do i need to modify the wires, do i need to change the power to the bulb? You can often find straight-across LED replacements for most auto bulbs that fit into the same sockets. Try superbrightleds.com They have a wide selection of LEDs for Auto applications. AND....if you want a bright blue flashing security system warning light on your dash to match your cool new LED interior lighting: http://us.lexusownersclub.com/forums/index...showtopic=46956 (how's that for a shameless self-serving plug!) :P Quote Link to comment Share on other sites More sharing options...
